Mathcad re-installation
Salo
After having given-up with my unsolved dll problem (see discussion http://communities.ptc.com/message/154574) I found out that I cannot reinstall MC 14 on a new machine, since I will lose my license at all.
As a last solution I am ready to format the gard disk and install MC from the CD. Questions:
1. Will it work?
2. I have only a key no. Is it enough?
3. If I format I will probably want to update Windows. Should I expect trouble?
Thanks!
rag
(To:Salo)
1. Will it work?
Thanks!
I may be wrong but I think that formatting the hard disk without saving your licence.dat is not a good idea.
The key number you have, entitles you to obtain once or twice (depends upon which kind of licence you bought) a licence from PTC. Later (e.g. if you change your hardware) you have to contact PTC licencing support to (possibly) obtain an additional licence file. While I have no personal experience it is said, that they react quite cooperative if you ever have the luck to really get in contact with them.
As I understand it the keynumber you have has nothing to do with the license file itself (other than being a necessity to be able to obtain one). Unless you are working in a company using a Flex-license-server the licence.dat, which is located somewhere in the directory you installed Mathcad into, depends either on the MAC of one of your network cards or on the volume-serial-ID of the harddisk partition. The latter ID will be changed if you reformat or repartition your harddisk. So in this case you should not only backup your licence.dat but also that volume-ID-number. Ther are tools around which let you set that volume-ID to any numer you want.
A FAQ at FH-Dortmund (http://www.fh-dortmund.de/de/studi/fb/3/personen/mitarb/wambach/lehre/Mathcad_FAQ.php) says you can find such a tool at http://technet.microsoft.com/de-de/sysinternals/bb897436.aspx
So in any case don't reformat your HDD without backing up your licence.dat and probably your volumeID-Nr.
I just looked at the thread you mentioned and saw you already were advised to contact PTClicensing and also to backup your license.dat before reinstalling. Nothing was said about reformatting, though, which could get you into troubles because of the changed volume-ID
Regards
Rag
MikeArmstrong
(To:Salo)
Try contacting the Mathcad License and Install.
Mike
My problem is still unsolved. I got a new license fom PTC and tried to re-install MC14 from the disk and get the pop-up requiring to instal .NET framework version 2.0.50727. I installed it and still am getting the pop-up. Any advice?
BTW I may consider taking a chance and install it in another computer running on Windows 7. Will it work?
Thanks Mike and all the good people
RichardJ
(To:Salo)
You should download version 14 M020 from the PTC web site and install that instead (which will require dotnet 3.5).
Some people have had problems with Windows 7, others not. I think the 64 bit version is the one that has most or all of the problems.
I've forgotten, but which service pack are you running on XP?
