Hello Everyone,
I have a question, wish learning and really need help. It's about "Matrices and Solving Equation"(3).
Thanks in advance for the time and help.
Best regards,
Loi Le.
Hello!
Please see the attachment (files for versions of Mathcad 12, 15).
Many thanks for your response, Valery. I think I am new with matrix multiplication. My question should be :
Thanks again,
Loi Le.
Hello!
OK!
I tried to find a symbolic solution.
And why MinErr not Find? Find is OK too!
And of course you can also use the function "Find" too:
I greatly appreciate your answer to my question, VladimirN. And I still have a query and need a explanation ( only for the last line ).
Loi Le.
Loi Le.
Loi,
Please see the explanation from Mathcad Help (hotkey "F1"):
And simple example (returns "1" if "x=y", and "0" otherwise):
P.S. And in your case, equation to be solved must be defined using Boolean equals ("=", hotkeys "Ctrl"+"=").
VladimirN,
I was wondering about "How many solutions the problem could have ?"
Thanks for your help again.
Loi Le.
Another example has at least two solutions :
Loi Le.
Now I got it, VladimirN. ( with following example )
Thanks again,
Best regards,
Loi Le.
