Hello All,
In the attached program, I have calculated root mean square of the residual. Could anybody check the procedure and see if I am doing this in the correct way please?
Thank you in advance.
RMS is Root Mean Square. What you have would be called RSS, for Root Sum Square ![]()
Thank you Richard.
