Modeling ODEs in State Space and using test data as a forcing function
I am using Mathcad Prime 4.0 M010
Looking at Task3-1: "Modeling ODEs in State-Space" in the help file it does not appear that the C or D matrices are used in the state space solution. Can you explain how these matrices would be included? Also, is it possible to use test data (force vs time history from a load cell) for the input forcing function instead of an equation? If so how would this be accomplished. Thanks!
