NaN as a result
YA_10963798
NaN as a result
I don't know why I getting this kind of result.. I tried everything. It is on page 15 . I use prime 9
Thanks in advance for your help
(To:YA_10963798)
Whenever in  any calculation a NaN is involved, the result is NaN.
Maybe a utility  function to do the vector multiplication ignoring any multiplications with NaN involved could help:
Applied to your calculation it looks like this:
Is this somewhere near to what you expected?
The calculation takes some time as Prime has to multiply 3669*2=7338 times two 3670x1 vectors  and a user-written function using augment and filterNaN isn't very fast.
Prime 9 sheet attached
9 REPLIES 9
When you multiply any pair of vectors that contain at least one NaN, the result is also a NaN.
Stuart
I've got Mathcad Prime 10, so I can't post a worksheet that's useful to you.  Sorry.
YA_10963798
(To:StuartBruff)
so that means the whole results will be NaN.. and that will erase all other results?.
Yes, I’m afraid so.
Stuart
YA_10963798
(To:StuartBruff)
thank you for trying . I appreciate your time
(To:YA_10963798)
YA_10963798
(To:Werner_E)
Thank you that solved my problem
StuartBruff
23-Emerald V
(To:Werner_E)
Out of idle curiosity, I wondered what you meant by "takes some time".  Now I know.
Surprisingly, a brute force and ignorance method offers better performance.
Stuart
(To:StuartBruff)
Not such a big surprise. I suspect that "filterNaN" is the main bottleneck and not "augment" or the column selector.
The if function seems to be faster even though its used in the loop.
StuartBruff
23-Emerald V
(To:Werner_E)
Indeed, filterNaN does seem to be the larger bottleneck.  However, augment is not entirely innocent in these proceedings.
Stuart
