Hello Group,
This is my first time posting. I am trying to convert an excel program that I have used for years into mathcad in Prime 2.0.
the program takes two sets of data from a Abaqus simulation. The first set a data is fixed x and y based on seabed information. The second set is based on the pipeline that is laid on the seabed. the x values initally are aligined with the seabed but as the pipeline laid onto the seabed the x points on the pipe begin to become misaligned with the seabed x. I need write into my mathcad program the ability to pipe x that correlates to the seabed x so that I can compare the difference in the y. I have attached the mathcad sheet and the two external txt files that I read into the mathcad sheet
It is not clear from the worksheet or your description where your problem or issue is.
What are you looking for?
Also, you did not define WD.
