Need a smoother curve .......
aimtiaz
I'm attaching a prime 3.1 file . In which i tried to interpolate two sets of data to make a smooth curve like Excel plotting . But the curve is not so smooth , like what I'm expecting .
See please the attach.
But you need not a spine interpolation but a fittings.
(To:aimtiaz)
Unfortunately I can't read P3.1 files (just 3.0).
So here is a file using spline interpolation and a few regressions.
Valey is showing a logistic model but with different data compared with the Excel sheet ?
Werner,
Please find a PDF version of this worksheet in attachment.
(To:VladimirN)
Thanks.
So I see what the problem is:
This second abscissa value has to be either an undefined variable (if you dispense with the units) or a range variable. I had shown how to do it in my first reply - here is the version using units
VladimirN
24-Ruby II
(To:aimtiaz)
When you create the plot you just need to increase the step for the variable argument of function.
