Hello Everybody.
I need help with proving the above, in general case for p.
Thank you in advance.
Best Regards.
You may need to restrict the range of values of p that you want to prove it for. C(0) gives a "no symbolic result was found". C(1/2) does give a result.
I suspect you could prove it if you could restrict p to positive integers. I see no way Mathcad can do that.
Thanks for your time and response, Luc. And I'm making an attempt at doing that :
My MC14 have not given any output with error.
Regards.
And I'm making another attempt at doing that :
Loi.
