First time poster, casual user of MathCAD Prime 6.0, and have a question regarding setting up an equation that has multiple variable inputs (X = 1....100, 10; Y = 2...12, 2; Z.....) and present a table of the input versus output results for the given inputs.
The equation is pretty simple but I'm struggling to figure out 1) what I am missing to make it work and 2) to display a table that would show those inputs versus the output. Its probably something simple but it's eluding me.
Thank you...they should include a warning not to play with math without coffee.
I do have a follow up question, sg in the equation is specific gravity and is unitless. Same way with C value. If I put units on any part of the equation, the program will not continue. I can fudge units to make it work, or completely eliminate them but defeats the purpose of the program in my opinion, but is there a way to run an equation with one or more unitless numbers among variables and numbers that have units?
Thank you!
