Hi every one
Could someone please help me out figuring how i can tell mathcad not to show me any imaginary solutions
Post the sheet please.
Try adding some "assume" constraints
You have to be aware that Mathcads symbolics don't know anything about units, so m is an unknown variable which could be anything (even complex).
As it seems that you are searching a numeric solution with units, a solve block with Find can be an alternative.
here you go...
could you give an example of how to use it?
i tried but couldn't get ANY results
Thank you for your help...
very helpfull
