There's no maybe here, it's exactly clear what's going on. In Mathcad (11 or 15) there are two division operators that work exactly the same, but look different. You have : and you have /.
If you change the : to / you immediately understand:
The mathcad 15 xmcd sheet can be explored easily, since it is an xml file. In there you will find that for the second case (the lower left expression) the 6 and (8-4) are together surrounded by (implicit) brackets. wheras in the first case there are explicit brackets, only around (8-4).
Advice: do not use : for divisions.
Note that further confusion is possible due to the 6(8-4) wherein 6 could be viewed as a function. In fact you can actually define a function 6 (that is: 6 with a space in front of it, or even a non-printing character) that you can have perform any function you like, thus adding to the confusion.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
