I'm working on a differential equation for a class and I couldn't get it to solve, so I tried a bunch of examples that worked for others and I couldn't get those to solve either. I've attached one such file. I may be making some really obvious or stupid mistake, but there is nothing I could find similar to this and the press F1 for help is completely useless. Any help would be greatly appreciated.
-Eric
You're almost there. The prime operator looks like a single quote, but to get it, you need to use CTRL + '.
Or CTRL + ä in my German version 😞
Are there any plans to make the keyboard shortcuts work the way they are stated in the docs or tooltips also in non-English versions with non-English keyboards at last?
I have change in you ode ' on same symbol from menu and all is ok - see please the attach.
Ok thank you both! That would be something that would be useful to put in the help section for using odesolve within the program itself.
