Dear All
I could not open an XMCD file with Mathcad ?
Please is there any one can help me to open this file ,Please
Regards
Abdelazeem
If you just want to see what's in the file, without actually using it or converting it, you could use this tool:
https://community.ptc.com/t5/PTC-Mathcad/Can-t-see-your-sheet-but/m-p/636482#M187968
Please be more specific.
Did you get an error message when opening with Mathcad 15 (Attach the file, we may be able to see what's wrong), or are you trying to use a version of Prime to open the file (Prime cannot open real Mathcad files, only files of type MCDX).
Dear LUC
I open the prime mathcad and I am trying to open my XMCD file but the Mathcad cant see the file
Regards
Abdelazeem
The attachment is the XMCD file
Mathcad prime is not equipped to open (real) Mathcad .xmcd or mcd files. It can only convert them. For that you need to have (real) Mathcad 15 installed on the same computer.
You can install and legally use Mathcad 15 on the same computer if you are a licensed user of (any version of) prime. For licensing of Mathcad 15 you use the very same license file that you used for installing Prime.
Dear LUC
Thank you indeed really thank you , I appreciate your help
Please, If you have time can you run this XMXD file on your Mathcad version and share with me the output figure of the result, I am so sorry about that, but I want to check if the results is correct or not
Regards
Abdelazeem
Which one of the more than 10 figures in the file do you want me to check, without Mathcad 15 and without a licensed version of Prime?
I suggest you use my tool (https://community.ptc.com/t5/PTC-Mathcad/Can-t-see-your-sheet-but/m-p/636482#M187968) and look for yourself if the result is OK.
OK,thank you for your reply
Regards
