Pdesolve help
ptc-5198484
Pdesolve help
Hello-
I am trying to use pdesolve to solve the unsteady heat conduction equation for a 1D plate that has heat generation and a convective boundary condition. I have the following sheet, but it keeps saying "variable is undefined". I have never used pdesolve before, but I think I am doing it right. Any suggestions would be appreciated.
-Jon
Yes, you are doing right. One of the BCs creates the problem. I think you missed (probably a copy/paste error) to specify what is the difference in temperature at the end of the plate.
You used: Tair - T(z,t), but it should be Tair - T(zhalf,t). The solution obtained looks like in the picture. Please find the sheet attached.
Is this the solution you are looking for?
awesome! Thank you!
