Plane, sphere and cone
I want to solve three equations with three unknowns and display the solution on a 3D graph with two points - the roots of the equation.
I can’t find Vyacheslav Mezentsev’s utility (Mathcad 15 or Prime) for such drawing two close surface. Help please.
I would like to have someone in my town
The drawing you show does in no way fit the three equations you give!
Given the equations, the apex of the elliptical cone and the center of the sphere both are the origin and the plane does not necessarily intersect the cone axis at right angles!
Not sure if uni's tools will help you to get the drawing you are looking for. Find them attached for MC15 and P2.
Good luck!
Thanks, Werner!
Really!?
But I sure see that this must be the solution to your question 😉
If you really like the Tatlin tower so much, then you should buy a model or print it yourself ...
https://free3d.com/de/3d-model/tatlin-s-tower-9119.html
