Plotting Pursuit Curves
JimDickerson
I took pursuit curves from 2 different but similar sources and tried to plot them. They come out the same but not as expected. They don't look like pursuit curves.
The worksheet called PursuitCurvesODE came from Differential Equations De-Mystified by Stephen Krantz.
The worksheet called PursuitCurvesDED is from Ordinary differential equations and applications- Werner S. Weiglhofer, Kenneth A. Lindsay.
I'd like some advice as to where I'm going wrong with the plotting or the equations.
Jim Dickerson
May be the attach help you!
Thanks Valery,
But I only have MathCAD 13 and I cannot read your file. Can you describe your answer?
Jim
valery's sheet in version 13
Also here is a screenshot of the worksheet :
