If I convert a version 15 document to Prime the plots come over with the vertical plot labels on the left hand side.
Prime launches a new plot with the label on the right.
Is there a way to move the labels to the left that I haven't found?
Can't seem to get a screen grab that shows the cursor. Note that you need to first click on the axis label, then move the cursor until it changes to this:
You should get that cursor on the top, left, and bottom border of the label.
click and drag.
That's amazing! Thanks. But it could lead to some truly wonderfully misleading plots:
Sometimes when I prepare Mathcad Prime plot for publication I do so - move some part of the picture in new places:
The origin plot:
