Polylog
ptc-1368288
Polylog
I have removed all previous material. Polylog was introduced by a visitor redoing the black bodies project. There are several work sheets on that, therefore no need for more. For the particular application to imitate Mathematica solution, things are not clear at the moment and reconstruct needed when time will permit. This work sheet is then "polylog(n,x)" ONLY !
jmG
This work sheet contains the previous construct for the PolyLog(n,x) & the black bodies application, which application is shown in the two forms 1/. Direct integration ... 2/. Expressed in the PolyLog solved integral function.
Please help yourself with the unit system, repost as needed for the community. My "PolyLog" share is done, QED !
jmG
PolyLog(n,x) as the function,
the work sheet as the tool.
jmG
