Precision
ojoshi-2
3-Newcomer
Precision
Hi
I have revently starting using Mathcad and am a bit novice in it.
I have a simple query regarding precision. Have a look at the image:
Apparently beta being of the order of 10e-4 is rounded to zero and hence the calculation gives wrong result. Can someone please help me understand where I can make Mathcad calculate in larger precision but display in 3 decimals? Just like excel!
Omkar
An on-going issue with the entry of temperature units.
1°C gives 274K and the wrong answer for the first vaue of beta.
either 1K or 1delta °C should give the correct answer as in the attached
Regards
Andy
AlanStevens
(To:ojoshi-2)
You've used the °C function. This converts Celsius to K, so 1°C is 274.15K, so it's actually dividing beta by 274.15. You want beta to be per unit degree C, which is the same as per unit K, so just replace the denominator of beta with 1K.
Alan
Regards
Andy
(To:ojoshi-2)
Its not a matter of precision. Its because the difference of Temperatures can be quite tricky because Mathcad converts all Tempereatures tu Kelvin. Thats the reason why mathcad offers the Delta°C "unit".
Similarily you run into problems by division using other temp units than Kelvin
Here is a ways to get your 1.018:
ojoshi-2
3-Newcomer
(To:Werner_E)
Thanks guys, guess this was a classic rookie mistake! Easiest trick seems to be to use delta deg celius.
Cheers
Omkar
