In Mathcad 15, if you insert a vector image, like WMF or EMF, the program will display it correctly.
This means that even if you resize the image, the thickness of the lines remains the same.
In Prime 2, after you insert a vector image, the program convert it automatically in a raster image. You can see this by resizing it. The thickness of the lines increases when the image is scaled up.
Also, it becomes blurry !!! A vector image is never blurry.
Can anyone at PTC tell us if Prime 3 will contain a fix to this problem?
Thank you.
If you upload a vector image I will experiment for you.
Mike
Any result?
