Problem again with units
TR_9781963
9-Granite
I am getting again the same problem where in it states the units are not compatible
(To:TR_9781963)
Because Prime is not using SUC (static unit checking) , in Prime you should always add units where they belong, even though the value is zero.
Of course your second try with VA(PT,units) must fail because PT is unitless but units=mm.
