I'm currently working on preparing a rather large mathcad-document allowing me new scientific calculations on worm gears.I'm currently working on improving the existing modules in order to reduce the load for the computer.
I'm having trouble creating a certain data-structure. Previously I always used for-loops for performing operations. But this lead to many commands being executed even though they were not neccesary. Therefore I'm changing the existing code to a command-form that allows selective execution through if-queries.
Programming in Mathcad works well, but when I execute some commands I need to place the output in subarrays...and I cant get the right data-structure out of this...
Could someone take a look at the uploaded file an maybe tell me how I can recreate the old data-structure?
Kind regards,
Jon
Obviously you posted twice during the time the forum was literally unuseable as of non working moderation due to spam attacks. It still lags but at least we are able to post and thanks Rachel after while we see out post turning up live.
For my solution to your problem see here: http://communities.ptc.com/message/219587#219587
