Question about arg() function
Ilyaa1ien
How do I make so that was the result of the less -pi.
It is necessary for me to build a graph so as I need on this graph show that the function goes to -270 degrees but as soon as mathcad function comes to - 180 degrees mathcad makes leap up and continued to build the graph in the range from pi to 0. here is a screenshot how it looks
http://img152.imageshack.us/img152/3601/mathj.jpg
7 REPLIES 7
Any chance of providing a worksheet?
Mike
In Attach
RichardJ
(To:Ilyaa1ien)
You could use the angle function instead of the arg function. This is defined over 0 to 2*pi. If the phase goes outside of that range then you need to calculate a vector pf phase values, and then unwrap it.
I got some errors
http://img221.imageshack.us/img221/4990/65783339.jpg
RichardJ
(To:Ilyaa1ien)
Which version of Mathcad are you using?
Mathcad, version 14.0.0
RichardJ
(To:Ilyaa1ien)
You should download and install M020 (if you are a single user) or M030 (if you have active maintenance; do not install M035!).
