How can I gat a Real and positive root - see the picture and attach (Mathcad 15 and, pardon, Mathcad Prime 2.0)
Valery Ochkov schrieb:
What problem is wrong?
The last time the discussion went along the symbolic solutions of your cone-semisphere problem which Mathcad is not able to deliver.
But as I see Harvey was dealing with the original problem in your first post and I think his approach of making the functions dependent of the demanded ratio is generally a good one. Next simplification could be to get rid of the generic V and replace it by, lets say,1, as the ratio should not depend on V.
Unfortunately this approach does not help with the symbolic solution of the cone-semisphere.
We can simply remember the solution of this problem - zero, point and three eights:
Result in Web page WolframAlfa is the same in Mathematica 9.See attach....12 roots all contain the imaginary part.I tried different ways to get rid of the imaginary part, but to me did not work.
Easier problem for Mathematica, Maple etc:
Numerical no problem with Semispher-Cone and Semicircle and Triangle.
Compare pleace:
It is, in fact, possible to get Mathcad to display a symbolic solution to the cone and hemisphere problem - see attached. Can't see that it's of anything but academic interest though!
Alan
OK!
And what is it 0.888... in Mathcad?
OK!
Evaluate cot(theta)
OK!
Evaluate cot(theta)
No - ctg(θ)
It is also easy to remember (as 888) - I was born in 1948 (deg), the day was 23 (min). February in this year had 29 days (sec)
Ingenious ideas used in your sheet!
So it wasn't a Mathcad limitation but rather a user limitation
And what about a symbolic solution this problem. We must solve not one equation but a system of 2 equetions:
AlanStevens wrote:
That's one helluva size ice cream cone, Valery! Is there a particular reason you want a symbolic solution?
Only academical interest and a tool to check Mathcad, Maple, Mathematica etc.
Russian winters. Lots of ice. Very symbolic.
Yes!
Alan,
Great solution!
I think one use for this cone-hemisphere problem would be to reduce the rate of melting of ice cream. In that case, minimizing the heat transfer would be the objective, not the surface area. If we assume the air film has a resistance and the cone wrap has a higher resistance, then we can determine a ratio of the resistance at the cone to the resistance at the ice cream top. The ratio of the height to radius increases as this resistance ratio increases. I have a numerical result in the figure. I only did a numerical solution. I also haven't bothered to determine a typical resistance ratio.
I'm not sure which is more fun...working on this problem or eating an ice cream cone!
Alan and others,
It appears that MC is really particular in how this problem is approached. In the attached file, I changed one statement of Alan's (mine is highlighted). This results in the immediate symbolic result taking a different form, although the results are equivalent. The net result at the end of the worksheet is that the final symbolic result can't be obtained in a reasonable amount of time.
All I did differently was ask MC to do a substitution instead of me doing it by hand.
Harvey,
Yes, the smallest of changes can change the path taken by the symbolic solver - sometimes leading to a dead end. That's why one often needs to play around with the equations a little. Brute force and ignorance can't always be relied on - as I've often discovered to my cost!
Alan
Alan
Sorry, Alan!
The theta in the answer must have an unit not rad/deg but steradian - it must be not a 2D angle, but a 3D-angle!
We have 2D-angle in same problem but with Area (const) and Perimeter (minimum)!
I never seen steradians in Mathcad-sheet!
