Remove green brackets by text edit XMCD (XML)
qm
7-Bedrock
7-Bedrock
Is there any way to remove green brackets by text editing in a XMCD file (XML)?
Maybe is something I can replace/change as text and after that I perform a save in Mathcad 15.
Tkanks
StuartBruff
23-Emerald V
(To:qm)
View menu.  You should find that "Annotations" is ticked.  Click it and the parentheses will no longer show.   They indicate that a region has metadata (eg, the source of the original worksheet if you pasted it into your current worksheet).
Stuart
qm
7-Bedrock
7-Bedrock
(To:StuartBruff)
I need removal, not hiding.
StuartBruff
23-Emerald V
(To:qm)
I don't know of a way to do it through the Mathcad interface, but there are several methods you could try.
In Mathcad, click immediately after a region's opening tag and press backspace; this deletes the region's provenance metadata.  Editing a region also deletes the provenance metadata.
You might also be able to do it via the automation interface by writing a script that deletes all regional provenance metadata.
In a text editor, look for the <ml:provenance and </ml:provenance xml tags and delete them and everything between them, except for the <ml:define ... </ml:define region ... this is actual maths part.  The xml file format is not well documented from a user perspective (as far as I know and unless Maintenance customers have access to resources I don't), so all I can go on is inspection of a region with metadata, which looks something like the following:
  <math optimize="false" disable-calc="false">
[[[ Delete the <ml:provenance bit ... ]]]
    <ml:provenance expr-id="1" xmlns:ml="http://schemas.mathsoft.com/math30">
    <originRef doc-id="...  </originRef>
    <parentRef doc-id="...  </parentRef>
    <comment xmlns="http://schemas.mathsoft.com/provenance10"/>
    <originComment xmlns="http://schemas.mathsoft.com/provenance10"/>
    <contentHash xmlns="http://schemas.mathsoft.com/provenance10">0a73aa6fb0c58b88ada5b8d849c4dbb4</contentHash>
[[[ up to here ]]]
[[[ Keep the bit ... ]]]
    <ml:define>
      <ml:id xml:space="preserve">k</ml:id>
      <ml:range>
      <ml:real>0</ml:real>
      <ml:apply>
        <ml:id xml:space="preserve">last</ml:id>
        <ml:id xml:space="preserve">x</ml:id>
      </ml:apply>
      </ml:range>
    </ml:define>
[[[ up to here ... this is the actual region math definition]]]
    </ml:provenance>
[[[ up to here ]]]
  </math>
It would be wise to keep a backup copy with provenance if you adopted this route, just in case any regions differed from the above xml format and give rise to errors in the converted worksheet.
Hopefully, somebody will have some better options.
Stuart
