So is it possible to let Mathcad represent the result in terms of even and odd cases?
Right now I only know to define n:=0,1..100 (for example)
Then write the complex equation and Mathcad will give a 100 by 1 vector (half of which are 1 and the other half are -1)
The result is not concise
Thank you in advance.
Shawn
How about
You can do this:
It's not quite the form you want, but I think it's as close as Mathcad will get.
