On 3/20/2009 1:13:30 PM, jmG wrote:
>Alvaro,
>You had that question before,
>but recollect that I might
>have been dense or otherwise
>not clear how it works. Here
>is an example.
Hi Jean. I see some other post from you (and I can't see all posts, so, I assume that probably there are a lot), exhibing the benefits of the use of root, whith susseffull, and I agree that they are elegants solutions and your use of root is powerfull.
Now you demonstrate a technique for discretizing a problem with the help of root and how to handle the RootOf' maple function, without using allvalues (anothe maple function), but using mathcad functions.
>It would be
>interesting 14 users try it
>and comment. You can argue the
>Given/Find will do, but my
>point was the Mathcad-Maple
>RootOf(,,,,).
I haven't mc14, but what I can see in a few momment was only that for simbolycall evaluations root need the complete set of arguments, or something like this. So, I think that there are chance to have goods results in mc14 also.
>Mona, this is not reverse
>engineering
>or braking the code, just a
>"recast".
To understand some questions (like how roots are implemented in mu-pad, and see their capabilities), I think that who are interested can read mu-pad help, which is free as chm somewhere in the web. (So, actually you don't need install anything. I remember that I point one direction in the collab, but can't found where). And this is not reverse engineering, only is reading how the programs are working reading their documentation.
The function that I found usefull for me in maple was isolate (a very simple function, but related with root). This avoid-me to make some simple keystrokes errors. But this is only in mc11 working model.
![](upload/isol_example.gif)
Regards. Alvaro
