Save as HTML bug
AlvaroDíaz
Save as HTML bug
In mathcad 11 links to mcd files are converted to htm ones saving as web page.
Checking help from mathcad 14 I understand that this feature holds (if this is what meaning "Mathcad hyperlinks are exported as .HTM anchor links in standard HTML markup.", but don't works: mcd files with normal links to another mcd file not make the conversion to htm files in the links when saving as web page.
Regards. Alvaro.
Related to the above, but not the same:
Hiperlinking as popup to a file that doesn't exist generates a beep and critical error message, enough to know that there are something wrong. Accepting the mistake mathcad now open an empty popup without any purpose (those popup can't be edited and save to make the missing file, for example). Also close mark it's minuscule. A beep and close two windows it's too much penalization for this error.
Regards. Alvaro.
