Sig Proc pk - Multirate error
PhilipOakley
Following on from
http://collab.mathsoft.com/~Mathcad2000/read?126506,11
I am re-coding some extended wavelet transforms. At their core is a multiple filter bank approach so I am using the signal processing pack's multirate function.
However it appears to loose values from the results array when using upsample m=1, down sample n=2, and daublet(6) as the filter.
Has anyone else found this and forund a formula for the returned length?
Philip Oakley
PhilipOakley
(To:PhilipOakley)
I didn't manage to resolve the problem with multirate having an indeterminate return length (especially with 1:2 ratio and variabe filter lengths)
However I did locate an open source version of the upfirdn() function used in Octave and MatLab, which I have coded for comparison.
I can now use this function within my updated wavelet calculations, which are based on public versions in matlab..
\\ correct mistake in Ly calc at 17.18 GMT+1 12/Aug/09
Philip Oakley
