Hi all,
We are implementing math in text for Mathcad Prime and are investigating conversion issues from earlier versions of Mathcad.
One question that came up is how to convert solve blocks inside text regions, since in earlier versions, the word "given" or other
parts of the solve block could be inside a text region.
Do you put solve blocks inside text regions? If so, can you post an example of doing so?
Do you write one big text region, with all your math inside it? If so, can you post an example.
I've seen some worksheets where people have created one big text region per page or even stretching over more than one page, and embedded all their math regions inside that text region. See attached Mathcad 15 worksheet.
Since solve blocks in Mathcad Prime are now a container, the conversion is not straight-forward.
If you have other ways that you'd like the solve block that started out inside a text region to appear, please post what you'd like.
Mona
Mathcad Program Manager
PTC
