Stripping units off variables
Raiko
Hello y'all,
here's a snippet of a larger program. I'm trying to strip a variable of its units - or not if unnecessary.
Unfortunately, my routine doesn't catch the error and throws an error instead.
Does anybody has a suggestion how to do this?
Thanks in advance
Raiko
P.S.
I'm using MC15 V030 on a Win 7 machine.
(To:Raiko)
Raiko Milanovic wrote:
Danke Werner, gute Idee!
Ich habe trotzdem das Problem, daß ich dann die, Millimeter in meinem Fall, Variableneinheit sich auf die Grundeinheit skaliert - also Meter. Wie kann ich das in den Griff kriegen?
Ich fürchte leider gar nicht. Die Symbolik sieht bei einer Variablendeklaration noch die Einheit, mit der die Definition vorgenommen wurde, aber die Numerik skaliert immer auf die Grundeinheit .... UnitsOf(5 mm) = 1m.
Abhilfe kann höchstens schaffen in einer eigenen Variablen die gewünschte Grundeinheit mitzuschleppen und durch diese Variable (1 mm) zu dividieren.
7 REPLIES 7
(To:Raiko)
Don't use the if-statement.
Simply divide by UnitsOf(thick) in every case. It does not harm to divide by 1 😉
Raiko
(To:Werner_E)
Gruß
Raiko
(To:Raiko)
I don't think you need the IF statement..
Be careful with the units. Remember 'SiUnitsOf(z)' and 'UnitsOf(z)' return dimensions of z scaled to the default SI unit.
Thank you Mike. I just noticed the very fact you pointed out 😉
Any idea how to handle the scaling issue?
Raiko
I have looked into this before and my 'lazy' answer is no. I did start to write a program to handle any unit but it became cubersome and I gave up. If I require to strip units, I tend to do it manually and hide in a collapsed area.
