Student licence not working anymore
MI_9350935
2-Explorer
Hello, this year in January i requested a MathCAD Student Version and received a licence file. 2 months ago my laptop had to get a fresh reinstall of Windows and now i can't get the full version of MathCAD working with the old licence file. What can I do? Thanks in advance. Matteo
@MI_9350935,
Probably your license file is pointing to old Mac Address and after reinstalling Windows OS that Mac address must have got changed.
Could you share your existing license file? Also, share log file (ip.log) which gets generated by running command "ipconfig /all > D:\temp\ip.log" in Command Prompt on your machine (use different drive than D if not available).
Hi rghadge thanks for your reply. I have attached the licence file, but I don't understand what that command you provided should do. I tried changing to my OS drive C: but it doesn't do anything.
Thanks for your time.
EDIT: since it seems that I can't upload the licence file (i get the following error: "The attachment's sw_license_email_4439337.dat content type (application/octet-stream) does not match its file extension and has been removed.") I will just paste the text from the file here. For privacy I removed my address, phone number and full name.
#License Pack for Session ID 4439337
# PTC License Pack
#License codes for PTC Product.
#Cpu 74-46-A0-3A-88-78
#Contact : ________________
#Address : ________________
# : ________________
#Email : mingegneri0@gmail.com
######### Mathcad #########
#Feature Line Type = INCREMENT
#Feature Name = MATHCAD
#Feature Version = 24.0
#Version = Prime 4.0
#Number of Copies = uncounted locked license
#Supercede = Y
#Issue Date = 03-JAN-2020
#Expiration Date = 02-FEB-2020
#Node Locked Option = WLO
INCREMENT MATHCAD ptc_d 24.0 02-feb-2020 uncounted \
80F08060593B62F44C57 VENDOR_STRING="VSVER=2.0 \
LO=(19)" HOSTID=PTC_HOSTID=74-46-A0-3A-88-78 \
SUPERSEDE ISSUER=PTC-WEB-MATHCADPRIME4EXT \
ISSUED=03-JAN-2020 NOTICE="mingegneri0@gmail.com, " \
SIGN2="1809 130A 3FED C122 DC3B 1EA3 C983 82CB 1631 \
87CA F19A 8B8F 1BDF D6EF 3666 1529 AEC7 ED4A A6C6 \
A144 A5D8 2786 20B0 6C42 5756 BB1C 6DC5 59F1 2A26 \
E49E"
@MI_9350935,
Seems your license is expired and hence you are not able to activate full functionality of Mathcad Prime. See below lines from your license file:
