Is there a way to define sub - routines at the end of the program like -
a=3
Ans=cube(a)
cube(a)= a*a*a
PS: I dont want to combine the call function and function definition.....
Thanks in Advance,
Prithivi
Yes, you can call one user defined function from within another.
You can even define the called function at the end of the sheet if you use a global definition. But in my opinion global definitions should be used only sparingly if at all as they make a sheet harder to read and debug.
I would rather prefer putting the definitions you want to hide in a collapsed area at the top of the sheet.
cube(a):=a^3
