Summation in if-loop
  • September 8, 2023
  • 2 replies
  • 3549 views
Hi
I want to create a loop that for the next interval add the results in the previous interval etc. I have made an attempt in the following program, but something is wrong. Any help is appreciated.
Best answer by Werner_E
Or you may use a more generic approach
Maybe this is what you are looking for:
Because a "return" statement stops a program from running any further, you can also write
Prime 9 file attached
Not really, I want the diagram to look like this (Excel).
f(0) = 0
f(4,5) = 0 + 4,5x9 = 40,5
f(8,3) = f(4,5) + (8,3 - 4,5) x 7 = 67,1
f(11,3) = f(8,3) + (11,3 - 8,3) x 8 = 91,1        etc...
Hopefully you understand what I'm looking for 🙂
23-Emerald I
September 11, 2023
Werner's formula is precise and well done!
But this is really a simple integration,  Attached Prime 4 Express.
(Extension to the second problem, above the water) will require definition of sign conventions.
😉 Its only simple once you found a way to automatically choose the correct gamma-value for every depth, like you did with
