Hi
I have a problem, i don't find why ?
(equations for intersection point of 3 planes)
Probably syntax error ???
in first solve block, i have copy / paste equastion of symbolic evaluation for plane equation
Please attach your worksheet, rather than a picture. (You don't show what P1M or n is...)
If you want to work symbolically, then work symbolically. Something like:
It's great !
Thanks for all
sorry i'm a newbie ![]()
What you try does not work in Prime (and also not in real Mathcad, at least not in MC15).
But there sure are a couple of workarounds which also avoid to use copy and paste.
Symbolic "solve" comes to mind:
or you define your "equations" as functions dependent on the variables you'd like to solve for to make the numeric processor happy and use the solve block without symbolics:
