Symbolic programming
- May 12, 2010
- 1 reply
- 1693 views
I use M14's symbolic programming capability to develop very complex systems of coupled ODEs from relatively easy to read "double entry book-keeping" tables of financial flows. The Mathcad program to do this is a mere 5 lines of code
The identical code in Prime gives me an error message that indicates that the col() function behaves differently in Prime than M14.
Secondly, even when this is fixed, the program doesn't work-it just returns a matrix of zeros.
Can you check this out please Mona? If Prime doesn't support this trick, then even though the new "Alpha" does a much better job than the original "Beta", I still won't be able to migrate from M14 (or M15!) to Prime.
