I am trying to find the value for D from a Function but Mathcad is saying that is undefined. I have also tried with the solve function but seems not working. Please help. Please provide with a version 10 file
Here you go.
Should (continue to) work in a fortnight for you, when your trial period expires and your Prime turns to Express mode.
But be sure to check that the replacements result in the correct vectors for you.
Try this:
I get:
But I had to replace your programs with simpler structures to allow it to run in express.
success!
Thanks Luc, is 0 ft and 24 ft the range within which the trials will be performed to find D? ALso, what if I use "solve" function? You mentioned you replace my program with simpler structures to run in express. Can you please share a Prime 10 version of the file.
THank you so much!
Here you go.
