How to tell the symbolic processor that n is an integer so while evaluating
cos((n+.5)* pi)==>0
and sin((n+.5)*pi)==>1
is there a way to force the symbolic process to do that once it sees these expressions it will just replace them with 0 or 1
The reason I am not using n as integer range is: this is part of a long calculation/derivation
cos((n+.5)* pi)==>0
You might want to think more carefully about the values you've suggested for the cosines and sines! However, try using both the 'assume integer=n' and 'simplify' symbolic qualifiers.
Alan
Thanks Alan I did not know about that "how to use the qualifiers assume n=integer?"
You think there is something wrong mathematically!
Well, cos((n+5)*pi) is -(-1)^n when n is an integer and sin((n+5)*pi) is 0.
Alan
I just checked it. Thanks for the great observation. I am trying to use the same subroutines instead of rewriting them to set sines and cosines. On the other hand I could not figure how to tell Mathcad n is integer.
I have corrected it. Thanks a lot.
Here is my attempt
It would be better if we can sort of declare n is integer for all instead of having to declare it every time I do the symbolic process..
Chad G. wrote:
Here is my attempt
My tired old eyes read your .5 as 5 earlier!
I'm not clear why you want to call the function every time anyway - why not just use 0 or 1 (though I notice your latest function is somewhat different - contains an n in the denominator)? Do you need to call it with non-integer values as well?
Also, why do you need a symbolic solution?
If you were to post a worksheet showing what you were really trying to do, we might be able to suggest something slicker (then again, we might not!).
Alan
Mine too!
But at least I don't drool yet ![]()
