Symbolics Help
ELSID
8-Gravel
Symbolics Help
Working with symbolics is not my strong point. Need a little help with questions on the sheet. Based off of Dr. Alan Stevens critical thickness insulation work. Mostly symantics ... so driving me crazy.
AlanStevens
(To:ELSID)
ElSid wrote:
Did not understand the second part
AlanStevens wrote:
--> Replace T.sat with either T.s or just Tsat (i.e. no subscript) It will then result in T.s - T.air rather than -(T.air - T.sat ) .
See attached.
Alan
11 REPLIES 11
RichardJ
(To:ELSID)
One thing you should always remember when using the symbolic processor is that it does not make implicit assumptions like you do. If it doesn't do what you expect then a liberal dose of the "assume" keyword can work wonders
ELSID
8-Gravel
(To:RichardJ)
Arrg! I had the R and t>0 on a previous section ... thanks for the catch. Is there a way of forcing the 2pi to the numerator? What about the negative sign?
RichardJ
(To:ELSID)
Solve first, then simplify to get rid of the weird formatting, then force the ln formatting.
AlanStevens
(To:ELSID)
Think of P/2pi as P1 and solve for P1. Then set P:=P1*2pi ->
Alan
RichardJ
(To:AlanStevens)
Interesting observation. I wonder why that makes any difference. I would expect the formatting to be independent of the choice of variable name.
AlanStevens
(To:ELSID)
See attached.
Alan
ELSID
8-Gravel
(To:ELSID)
Revisitng a post with a file that I had working in MathCAD 14 and for some reason will not work in MathCAD 15 M030. Hoping the Collab can help. Problem starts with equation 5 where it appears I can not longer define a variable based on a symbolic. See screenshot
(To:ELSID)
Thats "normal" (nevertheless strange) behaviour that you dont see a symbolic result when you use a symbolic inline evaluation in an assignment.
Simply evaluate P.F later and you will see the correct result.
You used a font which seems not to be installed on my machine, so the nominator is shown as a small rectangle.
Depending on how wide you'd like your sheet to be spread you might consider changing that.
ELSID
8-Gravel
(To:Werner_E)
Werner,
MathCAD just crashed. Why did it work in MathCAD 14? You are correct and I will revise the sheet. I shouldn't have to to do this much re-work btween 14 and 15!
(To:ELSID)
ELSID wrote:
Werner,
I am using MC15 (M030) and didn't experience that kind of problem.
