When trying to solve a variable equation, Mathcad Prime 3.1 will not allow me to symbolically solve a specific variable. The attached example shows that it will not solve for x in a simple equation such as "ax+b=0". If anyone has any idea why this is the case, your input would be greatly appreciated.
Looks like your equations don't contain a variable x. All I see is a variable xc. If you mean x*c you will have to type it that way.
You forgot about the multiplication sign between "x" and "c":
