On 2/21/2009 1:04:30 PM, paulk20050 wrote:
>jmg, I imagine you have
>written, helped develop the
>Mathcad software? true or
>false? and would therefore
>defend it to the day you die?
==> I never wrote anything for Mathcad .
==> If my recollection is correct, you wanted d/dx[tan(x)], which Mathcad gives directly but you wanted going through pain and prestige of what you did. Then your bracketing was incorrect and it toke quite a while for many to admit. Then I made my point that your book though right is incorrect as well as your final answer as you switch the domains. I never claimed your answer was wrong/invalid... simply pointed "incorrect" because you have introduced an identity before the next algebraic step that is to simplify/reduce.
That case is not too detrimental but symbolic CAS do follow the rules ... symbolic is "Advanced Algebra" that follows rules as well as "rules of domains".
>Is there no way that Mathcad
>can be made to make
>substitutions? in this case
>sec^2 for 1/cos^2.
==> It would have to follow unknown rules.
sec� is implicit of the complex domain and will expand in the complex domain as well as in the tan(x) domain. For your question I take the answer from Mathcad. Look for more in your book or expect more from collabs. Mathcad is not a handbook.
Make sure you give your carpenter the right tan(x) domain for the roof. Otherwise you might just get a rabbit hutch and will be your fault in the court room !
jmG
