Do you HAVE to do these in Mathcad...? Which version of Mathcad?
Because this is homework, as said before:
You (YOU ! ) have to make a start. If necessary start by learning how to use Mathcad, do some simple things, then try to work your way to one of the assignments.
If you run into trouble, come here, post your Mathcad worksheet (not a picture, not a pdf!) and explain your trouble.
Then we can help.
Then we can help.
I have a suspicion that this person, knowing the Matlab well, wants to solve tasks for the third person using Mathcad.
