I crashed PTC Prime 8 and the saved file is not able to be opened. The file is 93.8 KB so I think the work should be in there. If someone could help restore the file, I'd greatly appreciate it.
- Rathet
Hey Werner_E
Thank you very much! for this attached file.
The attached file should be more like what you had.
Big Thanks to Luc I'm really grateful.
-Rathet
