Can somebody point out where did i miss out in my program above? if I try "f" above using matrix "a", I get an error, but when I try "f1" using "b", its fine.
Sorry, I didn't see your post beofore I posted. Please see attached.
Mike
Please, attach a worksheet.
As Vladimir said please provide a worksheet.
But I can see the problem without one, a is a matrix and b is a vector. You need to specify which column of a you want to look in or write a program to search through both columns.
Mike
I think I understand a little bit what you mean mike....the above is what I've got, the result of something like "f" is what I wanted.
thanks....
Mike
