Time Domain Analysis 1 of 2.mcdx.pdf
KarlBogha
Hi Physics students and physicist.
Prime 2 file on how to create signals.
Part 1 of 2.
Use it and or pass it on to who may need it.
You can request the Prime file.
N/A.
Hello Karl,.
Thanks for your examples.
Could you join your two files of premium.
Kind regards.
Denis
KarlBogha
(To:KarlBogha)
Hello Denis,
I can combine the two Prime files and pdf it into one pdf file.
I had it in two files due to the worksheet was long and it may have problems associated with reuse of variables of the same name (so here I usually initialise the variable to zero).
Right now I have my Prime 2 program in an obstacle, I get an exception handle error of some sort and had put in a request to the Academic Support. When I get it running I will get to it. Remind me in a weeks time just in case.
I am anxious to get to the Frequency Response chapter of the book because here there is Laplace and Fourier applied. Its been on hold due to job hunting and studying other areas in power systems. Cheers.
N/A.
