Hello all,
I ahve this irritating problem in VB code. I'm trying to add up to arrays of equal dimension via a push button control in MathCad (15 on Win 7) so that the output get's written only on demand to a file. But to no avail. Can't figure out what's wrong - see attached MC file.
Does anybody know enough of the BV in Mathcad to help?
Raiko
Which summation are you trying to achieve?
Mike
Hi Mike,
summation in the sense that I want to extend the array by the array I'm adding up. In the example I have a column array (vector) which I'd like to extend with another vector of equal size so that the result is a two-column vector.
Cheers
Raiko
Oh, so you mean like augment?
Mike
Correct!
I haven't seen that done before and not an expert on VB by any means.
If you don't mind me asking, what is the purpose of augmenting using a push button? Because I have few ideas to get around the issue.
Mike
Hello Mike
whenever I'm computing something and I do change a parameter I can see it with one set of parameters. Changing that changes the results, therfore I want to store the results in an intermediate file and only after I've changed some parameters and settings to add another set of data (i.e. on the click of a button). Later I'd retrieve the data for comparison.
I want to do it in VB as MC computes all the time and I can't control when it is stored in an external file.
Raiko
That's slightly different than what I had in mind.
I think you'll have to wait for one of the VB guru's to get involved. The only thing I could think of is passing multiple inputs and augmenting the data in a way it can be compared. But this is different from what you want.
Mike
Thank's a lot anyhow Mike
Cheers
Raiko
I have a smilar problem, wanting to permute design values and save desireable results for use eslewhere.
Since I know almost nothing about VB, I've taken a different path:
Use a Mathcad file WRITE or APPEND command, but disable evaluation of the command. When I get a result I want to save, I enable the command (which modifies the file), then disable it again immediately. This isn't as elegant as a pushbutton, it requires two right-clicks and two clicks and an enter, but it works. And all that clicking will be good training for Prime!! 😉
Hello Fred,
that's the way I did until now. Tedious but it works. However, since I saw the push button from the "Extra Components" sheet (writing data to a certain file only on command) I wished I could collect data this way. Is that a MathCad pipe dream?
Raiko
Raiko Milanovic wrote:
Hello Fred,
Raiko
I think it's a question for Mr. Jackson or Mr. Oakley!
I think it's posible, but I am really busy right now. I'll try to find some time to look at it soon.
Here are a couple of files provided by Collaboratory members.
