Values for Variable
the_viking-disa
Values for Variable
Its easy to have a variable x having values from 0 to 355 in increments of 5 by x:=0,5..355
But I want a variable say y, having values starting from 120,125....355,0,5,10....115 (order should be as given).
How do you declare such a variable??
15 REPLIES 15
It would be normal in such cases to use a vector,
and then use a range variable to index it. The
vector can be loaded by a suitable programme line
(probably two steps in your case).
Philip Oakley
thanks....can you help me with the programming part?
how will the program look?
== thanks....can you help me with the programming part?
== how will the program look?
Here's a couple of ways ...
Stuart
thanks a ton stuart 🙂
Also can you let me know good reference book/s for learning mathcad.
Sorry, I don't know of any. I learned Mathcad the hard way by just using it, reading the Quicksheets & Help files, and looking at the Collaboratory (plus attached files).
Stuart
>mathcad.
______________________________
There are lots of web site Mathcad.
Many have sheets to download.
A serious book about Mathcad would be, let say 2000p [�]. And now with 14 that is not the same at all than 11 and earlier versions, very few constructions will be compatible. Hopefully, by beginning of May 2010, I will have over 500 pages of MCADeng in my web site, just as a "starter tool". The remaining of the most precious content will be by the end of this year.
But no sheet to download, only *.PDF [PDFcreator].
jmG
>mathcad.
"Mathcad11 Users Guide" - the last good guide (available as pdf in some places)
I also have "Engineering with Mathcad" by Maxfield. ISBN 0-7506-6702-8, which is OK but by then I'd already used the 'Stuart' approach 😉
Philip Oakley
thanks jmg and philip....
@philip - yah...i did use stuarts method. I need some sort of reference coz I think I'll be working in mathcad for some time.
While trial and error and just doing is quite fine and necessary
apart from the Maxfield book(s) I have found
"Philip J. Pritchard - Mathcad, a tool for Engineering Problem Solving" very helpful.
Not 2000 pages but just 200 and very practical.
RMix
Don't forget to also check the resource center:
http://www.ptc.com/appserver/mkt/products/resource/list-books.jsp?&rccg=888&nav=5279&sec=5271&top=0&lang=en&section=mathcad_resource_center
Some material is free and worth reading (for example "Inside Mathcad: Solving", Inside Mathcad: Programming"). Some of the documents for older versions still have useful stuff too, so don't ignore them.
Richard
thanks RMIx & Richard 🙂
Catch collab work sheets on the fly,
try one month back for instance,
lot of projects going on or related material.
jmG
RichardJ
(To:ptc-1368288)
Please don't cross post. And especially don't tag new questions onto the end of existing threads when they have nothing to do with the thread.
Richard
Richard,
Sorry as i am new to this forum. hence i deleted it.
LEO
