I need the attached calculation of a spinde-driven gripper for a school project, but it doesn't work.
There are two things that are inexplicablefor me (in the yellow marked area; I think the problems below have the same reason):
Before I added the explizit- commands everything worked perfectly, but my teacher wants the numerical value before the result.
I would be greatful for any ideas..
I don't experience any problems when I open your sheet.
Which version of Mathcad do you have in use?
Here is what I see when I open your sheet with no modification other than separating the regions where you evaluate F1 symbolically and numerically a little bit.:
Your document working fine in Mathcad 15 M040. In attachment you can see a result of calculation. Try to recalculate the whole worksheet by using "Ctrl + F9" hotkeys.
