WRITEEXCEL problem in IF statement
Raiko
Hello folks,
I tried to write a routine that stores intermediate results only when I invoke it. For this purpose I'm using a list box that gives out a command variable (out) so that only the parts of the routine are executed that comply with this value. The subsequent routine has either to write or read to a given file data. All works fine and swell except that the first if condition is evaluated when I'm choosing the second one.
The file (MathCad 15 on a Win / 64 Bit machine) is added.
Can somebody spot the error?
Thanks in advance
Raiko
Hi Raiko,
in case out=2 you can get to the WriteExcel ( Z... statement without defining Z & I think that this is what mathcad is complaining about.
regards
Andy
Hi Raiko,
regards
Andy
Hello Andy,
the Z..statement was indeed misplaced. That did the trick
Raiko
