What is the problem? explicit function
  • January 15, 2016
  • 3 replies
  • 4977 views
his appeared only i use explicit,
Best answer by lawrencelawrenc
Thanks very much for help! I resolved it with change in Regional settings "Digit grouping symbol". It is a bag in the Windows 8.1, when select in Region: Russia, in place of digit grouping symbol is simple space.
when i change this in this form:
everything worked as it should!!!
Please post the worksheet.
on the page 7
Which version of Mathcad, which Maintanance release are you using?
And of course, as Richard already told you, you should post/attach the worksheet.
To do so choose  "Use advanced editor" at the upper right and then you get (at the lower right) the option to attach files.,
I'm use Mathcad 15 (M045).
It's problem appear everywhere. for example most simple:
No error for me (MC15_M010):
I'd suggest reinstalling Mathcad.
lawrencelawrenc1-VisitorAuthorAnswer
